Old 09-04-2019, 08:35 PM
flkeysdude flkeysdude is offline
Default Question regarding narrow or wide frame plow
Hi All...
I'm cleaning up the yard and found I have a plow that I never use. The distance (opening) between the rear lift forks on the lift mechanism is 7". Can someone tell me if this is for a narrow or wide frame tractor...???
Thank you !
Old 09-04-2019, 11:28 PM
Originally Posted by flkeysdude View Post
Hi All...
Thank you !
A picture would be helpful, since someone may have molested the undercarriage that I assume you are referring to and that would give us a better reference. I have seen (and now own) a WF (wide frame) undercarriage that someone has cut the arms off of and switched sides on in order to make a WF undercarriage work on a NF (narrow frame), so anything is possible. The WF ones are supposed to taper back and become narrower than they are at the front of the subframe (where it hooks to the Quick Attach (QA) on the frame, so the distance may vary from about 4" to about 7". The NF ones are supposed to run straight back and expand (not be parallel) as the reach the forks on the end so that they can rest on the supports for the footrest on the outside of the frame, so without taking a tape measure to the ones I have, I would say they are about 11"-13" apart at the back forks.
I hope this helps...Put that plow to some good use and have some fun!
Old 09-05-2019, 07:03 AM
Absolutely, need pictures.
Old 09-05-2019, 08:42 AM
Also, sometimes a little more description is helpful.
A "plow" can mean a lot of things to folks, I'm sure you know what you have, we don't.
A "plow" can be a moldboard implement for turning over soil in preparation for further tillage operations as in example, a garden.
Also a "plow" can be a mounted dozer or push blade one uses to move various
material like rocks, dirt, leaves, and that four letter word for frozen sunshine, SNOW ( forgive me for such blasphemy) in the middle of beautiful warmth.
A "plow" can me mean udder stuff like
I got plowed las nite and plum dun runned into a tree on da curve.
Don't see how it jus moved itself into da rode like that.
Old 09-05-2019, 03:38 PM
OK guys...my bad...!
The distance between the rear forks is 7"...hope this helps !
Thank you for your help...
Old 09-05-2019, 04:37 PM
How about a "side shot picture" that shows the profile of the arms ??
Old 09-05-2019, 06:18 PM
ironman's Avatar
ironman ironman is offline
I have a plow sitting here that fits a narrow frame and the fork distance is 7 inches. But I never tried to put it on a wide frame.
I do have a wide frame plow but it is not handy to measure so I guess I'm not much help.
Old 09-05-2019, 06:24 PM
ironman's Avatar
AHA, I found some pictures of the wide frame plow, so you be the judge....
Old 09-06-2019, 10:20 AM
Here are the side pics. Appears to be a wide frame ? Opinions welcome...What's a reasonable asking price ?
Old 09-06-2019, 10:22 AM
$25.00, the most 50.00.
Up to 534 and counting...
