#71
Dueling wheels.….
This ought to be interesting!!
#72
Had a request for the part numbers for the dually adapters, end plates, and lug nut/lug bolt set. These dually adapters are made for different rim/tire combinations, so that being said, the following parts number are for the “6-12” rim/tire setup ONLY. These are the 7” option.
These are purchased through www.extrememotorworks.com. • CC-01-001-700W (round 7” dually adapters 2 are included) • CC-01-050 (round cover end plates 2 are included) • CC-01-048 (Cub wheel stud/nuts 10 are included) I hope this helps!
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer |
#73
Finally got the dually wheels installed today! I also added valve stem extenders from the inner tires to one of the wheel weight holes so I can check both pressures from the outside wheel. One picture shows the stainless steel braided valve stem extender and a second picture of the outer rim face shows the two “Cub Cadet” valve stem caps.
2E2558B8-B6C1-4BED-A15E-886581D6D5D0.jpg BED85D61-F576-4144-985A-BC6649900F9B.jpg
#74
#75
#76
Final engine Pictures:
1513EE2D-2FBB-41E6-81C8-91C827FB255A.jpg C66C4739-AD76-4300-BDDC-8EB815B26A1F.jpg 95E0FC59-50B2-4134-9E2B-C220A0D3407F.jpg 899F6D43-B90F-40B8-9B12-5BF694ACE92A.jpg
#77
The duals look great, nice work!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
#78
Thank you very much for the compliment! I like the way it looks too
#79
#80
Duals and a stack, looks great!
