Old 06-20-2020, 05:54 PM
JaydenB's Avatar
JaydenB JaydenB is offline
Default Cub Cadet Original transmission
I just changed my Original's transmission oil, and now some is leaking out the hole on the axle housing that has brakes. What is it and how do I stop it?
Ih Cub cadets are tanks if you take care of them
Old 06-20-2020, 07:17 PM
IHscout79 IHscout79 is offline
Sounds like rear axle seals need replacing.
Justin
Old 06-20-2020, 08:40 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
there's a seal and an o ring in there. its usually the seal but the o ring will deteriorate over time
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending.
Old 06-20-2020, 11:46 PM
JaydenB's Avatar
You know the part numbers? How much are both
Old 06-21-2020, 08:01 AM
Click on the Tab at the top of the page that says..."Cub Cadet Parts & Service Lookup". Use "Cub Cadet" as the model for the Original. It will give you a complete parts breakdown and prices.
Old 06-21-2020, 12:10 PM
JaydenB's Avatar
Thank you! I never would have thought cub cadet mtd would have diagrams but they do! I figure I'll go to ccspecialitys and buy 2 of what I need so the other side gets done too
Old 06-21-2020, 01:27 PM
Sounds good.
Old 06-24-2020, 02:47 PM
JaydenB's Avatar
How do you get that piece out holding the seal and o ring on the left side?
Old 06-24-2020, 08:32 PM
There is a manual showing how it is done in the tech section.
