Old 07-07-2020, 07:02 PM
Originally Posted by MBY852 View Post
It just seems weird that the last 3 times I used it it behaved the same way, 15-20 min then quit. It may not be the pump.
15 minutes, then quit,,, is usually a clogged gas cap vent,,
Try it with the gas cap off,,
If it were mine, and still did it,,
I would set up a nurse tank (it would look like an IV bottle) and feed the carb directly, no tank, or pump, involved.
Only if it then runs, can you start looking for a problem.
I bought a two year old tractor, the FIRST thing I did was empty the fuel tank, flush it, and fill with clean fuel.
Now, I admit, that was a diesel, but, I did not like the way the fuel "looked"
The tractor ran MUCH better after cleaning the tank, and changing the fuel,,,
Old 07-07-2020, 07:30 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Haven't checked the flow to the carb yet. The flow from the tank to the filter seems fine. I read another post on here where a guy blew the line from the tank and a beetle came out.
Just curious..... when the engine quits, how long before it fires up again?
Plow blade
#2 Cart
QA36 snowthower
Old 07-07-2020, 07:56 PM
MBY852's Avatar
MBY852 MBY852 is offline
I really don't know exactly. Twice I had to push it back to my shed and maybe an hour later it would start up. Being that it only happened the last 3 times I don't have an accurate time frame.
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 07-07-2020, 08:01 PM
MBY852's Avatar
I'll give the gas cap a try first. I would think if the pump was bad it shouldn't act like that, work then not work but I'm far from being an expert on these kind of matters.
Old 07-07-2020, 10:15 PM
Ran into this exact symptom of run a while then sit for an hour to start etc that
you are describing. After these good fellas gave me the same advice to
make sure all was spic and span. I pulled and cleaned the tank replaced
all fuel line ( cheap fix) and cleaned all thing gas excluding carb and
fuel pump. That was 4 years ago and it hasn't missed a beat. My opinion
as a student here at OCC is clean clean clean. Then worry about the other
stuff.
Ken
Old 07-08-2020, 09:28 AM
MBY852's Avatar
stuff.
Ken
Thanks for that info Ken and to all the others for there help! I'll put a new fuel filter on and then drain the tank and put on or blow out the fuel line. The fuel filter definitely needs changed. Hopefully that will be the problem before I go and put on a fuel pump.
Old 07-26-2020, 03:29 PM
MBY852's Avatar
Well I tried it with the gas cap off. I put a new fuel line from the tank to the pump and new filter. I put a new fuel pump on (from fleabay) and it did the same thing so I put the original back on. It still only runs for about 20 min and thats it. When it quits the fuel filter hardly has any gas in it. So the only thing that I can think of next is the electric pump unless somebody has any other remedies.
Old 08-03-2020, 11:46 AM
Loader Loader is offline
I used a low 1-2 psi Facet #40177 in my 782 with a KT-17 Series II and wouldn't have it any other way!
Loader
102 with Snow Thrower
147 with wood chipper
782 rebuilt With 50" belly mower
1200 with Haban Sickle Bar
1450 restored with Roto Tiller
1512 with Snow Plow
