Old 07-26-2020, 07:44 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default Engine trolley lift
When I call this my engine hoist. I mean for a Cub engine only. Working on my 4 Cubs, Scag and butchering a few deer. My back can't take manhandling things anymore. My last engine removal I used 2 ladders a piece of strut and the winch. Much more controlled then lifting by hand. So I decided to upgrade to the trolley on the garage door track. When i'll make a lift I'll add 2x4 legs to the end of tracks for extra support. Not counting the winch I spent around $100.
2-1811's
1872
2072
Old 07-26-2020, 07:51 PM
spndncash spndncash is offline
I would not advise using any overhead door track to lift weight. they are very flimsy. Please be careful. the trolley and the motor will most likely all come down and hurt someone.
go buy some c channel and make a gantry crane or buy and engine hoist. most fold up out of the way when your not using them
Old 07-30-2020, 12:40 AM
steelsmith steelsmith is offline
I put up a single rail of 1-5/8"X1-5/8"X10' 12 ga. unistrut (P1000T)and 2 of the unistrut trolleys (P2950) by welding the unistrut 4 hole 90 deg. angles brackets(P1325) on top of the rail to line up with the over head beams in my garge. I then put 1/2 bolts though the angle into the side of the beams to hold it up and in place, so far I like how it has worked out for me.
I use a small 1/2 ton chan come a long to do the lifting and then can move things down the line as needed, If/when I need to do this again I will use the bigger rail 1-5/8"X3-1/4" slotted rail ( if I can find it) and then I can run lag bolts though the slotts and not have to do the welding like I had to this time.
Take a look into the unistrut its not hard to work with and it has a high load rate, I like what I've done with it so far but it would be nice if I could move a load side to side as well as frount to back like you have.
Joe
