Old 08-30-2020, 08:37 AM
Rbertalotto Rbertalotto is offline
Default Electric Linear Actuator Down Force Test
For those of you thinking about using a linear actuator to raise and lower your sleeve hitch. Here is a fabrication I recently built. This video shows that it is capable of lifting the rear end of a tractor that has near 400# on the rear wheels
https://www.youtube.com/watch?v=rwzxXMbHVWc
Old 08-30-2020, 09:07 AM
Pathfinders Pathfinders is offline
Default Nice lift on the tractor, awesome lift under the tractor
Great job with the tractor actuator. Not to high jack this thread but could you tell us about the in floor lift sometime. Thank you.
Old 08-31-2020, 12:37 AM
yodaddy yodaddy is offline
Nice job. What make/model actuator are you using?
2072 - mower and snow blade
1811 - Sims cab and 450 snowblower
127 - mower, snow blade, and QA36A snowblower
122 - snow blade, york rake, and log arch
Old 08-31-2020, 08:28 PM
here is the actuator I'm using. It came with the 782 when I bopught it. Brand new in the box!
Unfortunatly, no model number is available
The floor lift is a simple motorcycle, 1000 pound lift that was foot pump operated. I had the floor cut and converted the lift to Air over Hydraulics with a self contained pump. It runs off my shop compressor. Did this nearly 15 years ago. Can't imagine working on motorcycles or tractors without it!
