Trash can solution
After spending way too long manually hauling trash and recycling containers out to the road this simple solution popped up the other day. Using just some 1/8" flat aluminum and a few pop rivets the task is now much easier, just in time or the looong upstate NY winter. Although the brackets could have been permanently fastened to the blade I chose to make them slide on and off with a pin to secure them. Heavier metal would be a plus but I have no welding or bending equipment. Happy hauling!!
Cleaver idea. I like it.
Definitely a good idea...
129, 124 |
Did you test them full including any Raccoons?
Testing
LOL, They have not been tested full, including Racoons. I hope to see if they can handle the weight this weekend. I just saw an ad for low temp welding rod that will work on any metal using a Mapp torch. I may choose to rebuild these things with thicker metal if the rods actually work.
Good idea, let us know how they work out.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
Great idea! How are they to see around when driving? Possible to put in the back with a 3 point and a bar? Would also add more weight to the rear for better traction in the snow. I like your creative thinking!!!
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
No problem viewing where the cans need to go.. There are no obstructions. Between the wheel weights and calcium filled tires there is plenty of weight in the rear. I can hardly lift the weights or tires. The tires never lost traction while moving heavy snow. That will be re-verified tonight with the 2 + foot of snow predicted.
