Old 01-31-2021, 09:52 AM
fxrglide91 fxrglide91 is offline
Default 1983 Kohler KT17 24193
I am trying to find the front crank seal. I have found two part numbers I think:52 032 07 and 52 032 10. Can anyone enlighten me as to the correct one. I got these numbers off of another site, but the diagram was a little confusing as to the correct seal. Some one mentioned about diagrams on this site, but I can,t find them. Thanks.
Old 01-31-2021, 10:04 AM
At the top of this page you will see "cubcadet parts lookup"
go there and you will get the correct numbers.
Yes there are two flywheel seals.
The KT1's series 1, used a smaller seal dia. for the crankshaft than did the later
Series II and magnums.
The pto end uses the same seal early or late.
Old 01-31-2021, 10:23 AM
Default Kt17
I tried that function. Could not find the KT17 series diagram. Could be my lack of Computer skills.lol
Old 01-31-2021, 10:29 AM
Just tried the function again. Not seeing it. Any help would be appreciated.
Old 01-31-2021, 10:43 AM
ironman's Avatar
ironman ironman is online now
Here is a link to Series 1 parts manual. Scroll down to KT17-KT-19-KT21.
Page 16 of that manual looks to be the 52-032-10 using the spec number you posted.
https://www.kohler-engine-parts.opee...wnload-p-12023
Old 01-31-2021, 10:52 AM
You are correct. It is confusing. From the old Paper Manual, it "appears" that there was a change in the seal depending on the Chassis Serial Number of the tractor.
I will still keep looking for a better answer.
Old 01-31-2021, 11:13 AM
Further research indicates the front Oil Seal is: KH-52-032-10-S
Old 01-31-2021, 11:21 AM
Thats the manual I found.
Old 01-31-2021, 11:23 AM
I will check my Chassis # in a few minutes
Old 01-31-2021, 11:50 AM
My Chassis Model # has nine numbers, not six.
