Old 06-21-2021, 10:03 PM
Cubcadet_107's Avatar
Hope the seal works for you.
Most times reinstalling a seal does not go well, as they conform to the bore by
being squeezed just a bit and during a reinstall, they are just a bit smaller/looser.
----sometimes one gets lucky tho'
ya win some, loose some.
Well George, I guess I did get lucky with reinstalling the seal then, I've run the engine for quite a while now and it's holding up just fine. It's only temporary until I get the chance to buy a new seal.
I will say that installing it certainly took much more force to install than it took to install that metric one!
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 06-22-2021, 12:28 AM
If it drove in tight, that is a good thing!
Tight is always good, I'd leave it alone if it don't leak.
And you now learned what a loose fit causes.
