sleeve it and have headaches.
I wouldn't even waste the time and money. Find another block. There all over the place. There in wheel horses. There in lot of old 60s to 70s tractors. People sell them Toro, WHs for cheap because it blew the deck or what have you. or just don't know. You know what I am saying there.. lol My reasoning is, stress cracks. Yeahm sleeve it. but the cylinder will probably crack like a windshield does from stress over time. You loose the force holding the sleeve in. I could be wrong. old man ego will know better. but that's me and my thoughts. 6 cents as everything as tripled in price. hahha |
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Yes some blocks are model specific, like longer connecting rods different oil pans etc.
google it as some WWW. links no longer work, or not permitted here. |
but basic block is same... maybe dip stick big diff. bearing plate. but reuse old one. crank bad? no... reuse.. oil pan bad ?? no.... reuse. it should bolt up to the block.. before says na i would at least check but hey thats me.. i do all i can before i say na.. but ill go over to the corner. iam still looking for help on my issue.. so off to utube.. poofers .. |
I can't correct you. I don't actually know what you just said.
Ken |
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
