Old 06-06-2022, 09:03 PM
elevenpoint's Avatar
elevenpoint elevenpoint is offline
Default 44C deck
Apparently I have a early generation 44C deck on my 149. From what I understand the PTO deck pulley is larger than the deck belt pulleys, which I need a belt for the bigger pulley. It appears the PTO will run the larger belt but not sure about the mule drive pulleys.
I believe the 44C was not designed for the 149?
Old 06-06-2022, 09:21 PM
There are 3 generations of the 44 inch mower deck. There was models: 44, 44A, and 44C.
44 was designed for the 1x8/9 Series tractors
44A was designed for the Quietline Series tractors
44C was designed for the 82 Series tractors.
To make a 44C work correctly on a 149, the center deck pulley needs to be changed to a IH-59703-C2 Pulley.
The correct belt would be: IH-59971-C1 Belt.
Old 06-06-2022, 09:35 PM
Can I run the bigger belt without changing pulleys?
Right now I'm running a 1/2" belt but it is too small.
Was there a way to change the pto on the engine to take the bigger belt?
Old 06-06-2022, 09:47 PM
What I laid out, was the cheapest inexpensive way, to make it work.
You could look for a 44 model deck, and install that.
Old 06-06-2022, 10:02 PM
The mule drive pulleys would have been designed for the bigger belt?
I know my PTO will take the bigger belt as it is.
It was a new engine when I bought the 149.
Old 06-07-2022, 08:01 PM
Why would I?
I already have a set up for a bigger belt.
The belt you said won't work.
I'm down to a 75" as of now.
