So the hydro oil filter that came off my 125 is a part number 923-3014, the WIX cross reference is supposed to be a 51410 but it won’t thread onto the filter base. I took the threaded part out just to see if was doing something wrong, but I can’t get it to screw into the WIX filter. Any suggestions?
Like Hy-Tran, it's best to stick with the correct OEM filter. I don't trust the cross-references, especially with hydraulic filters. It's under $20 for the right filter from Cub Cadet, and then you know it will work.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
As far as hydraulic filters go, it's usually best to get oem because there are too many varieties. Same applies to some car engines, but not most.
OEM filters don't cost much more and are sometimes cheaper. This is speaking generally, as I do work on some larger equipment. |
OEM hydro filter ordered.
BS, Wix filters are probably better than OEM. Yes, I have had a Wix or 2 not want to start but eventually they did........but then again I don't use Hytran either.
Heard that others have had difficulties threading the WIX. Don't know what that's all about.
The OEM Cub filter is obviously manufactured by a well known filter company for Cub Cadet. Wonder which one it is?
I usually buy CCC ones but they're up to like $18.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
I just recently used that Wix filter on a customer's 1650 and the filter installed and preforms perfectly.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
