Is the choke fully choking, maybe needs to be adjusted
Thankyou for this info. I will take battery in for load testing
I have replaced plug and fuel filter so far. |
Thankyou for your info.
Keep us updated with what you find that works ! I learn a lot from others experiences and resolutions , a lot of posts just end in suspense !
I took battery to the shop and check it under load and was showing it be good
Yes at this time it's still hard to start,, battery has been checked and shows good under load. So iam going to take in to service shop and have the timing and coil checked.
I had the battery tested under load and showed it was good. Thanks for the suggestions, at least we eliminated that issue. I appreciate your time.
Cheers Eric |
