#31
Perfect. I agree that this is the simplest path forward.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
#32
Thanks, yeah, still waiting for this cotton picking rain to go away so I can try it out.
2005 CC GT2544 1980 IH CC 782 1957 Cub Lo-Boy 1993 Craftsman LT4000 |
#33
At last, sunshine! Had the opportunity to work the rake today and the only questions is,,,, why did I wait so long to get one of these rigs!? Love this thing. What used to take up to 2 days hand raking was done in less than an hour.
![]() The only bit of an issue was I'm used to the Farmall Cub's hydraulics in that there are adjustable stops to set limits on how high or low you want the lift to go and the CC is lacking that so trying to set the rake at the same height on each pass took some trial and error with imperfect results but I got better at it as time went on. Anybody ever come up with a depth control for one of these? Maybe something back at the hitch?
#34
I also wanted to see if there was going to be any issue using the drawbar while the hitch was attached so I hooked up the mini-haywagon and took it for a spin, No problem between the wagon tongue and the hitch.
#35
That little knob on th right takes care of setting the height.
#36
Hmmm, forgot about that. I'll have to give it a try. It's been a rough 48 hours. We took a lightning strike on Tuesday and it took out a lot of electronic gear. I've been pulling my hair out trying to recover and restore what I can so things are a little foggy.
#37
I do have a hard time with how responsive the hydraulics are vs most 3 points, like my IH 284 or the neighbor's B-series Kubota.
