#21
X2 on no loctite
#22
Get some gasket paper from your local parts store and make a gasket for it.
Easy to do as you already have the pattern right in front of you. |
#23
I've seen that on my stuff too. Don't believe it was Locktite. Probably a thread sealant. I've never replaced it on the bolts, and don't have a leak because of it.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
#24
Charlie has the cover gasket.
https://ccspecialties.org/clutch_driveline_rearend.html
#25
I put on a new filter, new gasket, and Hytran fluid. Works great now. I appreciate all the suggestions and coaching on this project. Thanks
#26
Redneck#1, What did you use to get the gasket off rear end? Super clean.
Thanks and have a great day. Bob |
#27
Used carb cleaner and a small stainless steel wire brush from Harbor Freight. Scraped a little with a plastic scraper and carefully on some spots with a utility knife.
#28
<edit> I guess I should have read to the end of the post before I chimed in LOL. I knew it was a fluid issue. |
