Old 01-01-2023, 04:03 PM
CubVideoCadet CubVideoCadet is offline
Default 1650 Ignition Problems - Don't Make Expensive Assumptions
Thanks to the helpful information in various threads, I was able to diagnose the no-start problem on my 1650. Before consulting the forum however, I first bought a new ignition switch. The new switch didn't fix the problem, so I was about to order a solenoid, and then I thought that maybe the forum could help...
It was corrosion in the positive cable inside the eyelet at the terminal. A little baking soda and water did the trick. Thank you!
Old 01-01-2023, 04:19 PM
Good to hear that you found the problem.
Old 01-01-2023, 06:52 PM
Common issue with the QL's.
Especially if they spend a lot of time getting wet.
Direct path for water to get to the ignition switch, right down through the slot for the hydro lever
Old 01-04-2023, 05:06 PM
To clarify, it was the positive battery cable at the battery end. I took the cable off and dunked the cable eyelet in a cup of baking soda and water a few times until the bubbling stopped. It left a good bit of crud in the bottom of the cup when I was done.
Old 04-21-2025, 05:56 PM
Seagondollar Seagondollar is offline
Default Corrosion inside the eyelet?
Here it is 10 years later, and I'm having a similar problem with my 1650. I was about to purchase a new generic battery cable locally, but I have baking soda and water. I will try this.
Otherwise, I may need to know what gauge wire and how long it needs to be.
OBTW, I'm a retired Electrical Engineer with over 50 years working on cars. But wish me luck, anyhow.
Old 04-21-2025, 06:44 PM
I tried the baking soda and water. No bubbles and I intend to get a generic cable (yes, I know about that one lead that comes off the input to the solenoid)
So, will a 4-gauge wire about 4 feet long suffice?
Old 04-21-2025, 08:39 PM
i'm thrifty (cheep some say) so I would just solder a new lug on the end.
Or if you know a electrician, he will have a crimper.
Old 04-22-2025, 01:17 PM
I also inherited the cheap gene from my father. But I can possibly bet that a new one won't have a break or weak section somewhere in it.
