Another Marketplace score on the cheap. The M12 runs well. It drives well. Came with a solid 44C deck/mule drive, and solid plow. Needs electrical work, and lots of cosmetics.
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
One of the first things I have addressed was the missing knob and cam on the implement height adjustment. The original knob's threaded part was broken off flush. After an unsuccessful attempt to extract the broken piece, I drilled it out and rethreaded it 3/8-24.
The hydro fluid looked to have had been recently changed, BUT a FRAM PH16 engine oil filter was used instead of the proper Cub hydraulic system filter 923-3014. I removed and replaced the filter using the proper Cub unit. The hydro seemed to have worked fine even with the wrong filter. The 782 I am doing servicing on also had the same PH16 FRAM filter on it. That hydro was also quiet and responsive.
![]() Quote:
Wouldn't be surprised if Champ Labs made the OEM one (they make Walmart's, AC Delco's, and a variety of others). I just stocked up on SuperTech for my Kohler/Briggs oil filters. USA made, good enough for a mower w/ annual changes, and under $4.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I just purchased 6 Wix 51410 transmission filters from RockAuto (923-3014 equivalent) for $8.13 each. My local O'Reilly wanted $19.99 for the same Wix filter and Cub Cadet wants $17.83. It's crazy how high prices are getting.
All filters are not of the same quality/specs. Even when manufactured in the same facility. I know for a fact this can be true. Only OE filters on my vehicles and equipment.
Ken Old fart - new to Cub Cadets Looking for a nice original low hour 1772 or 1782 |
Ooops, sorry 1711, I think we derailed your thread.
Looks like this 1210 now has a good home and someone who will take care of it.
![]() Quote:
Just how it goes sometimes. ![]() 1711, what's giving away a 1211? $200?
$100 for the tractor, extra set of wheels with good chains, a good 44C deck, and a solid complete 42" plow.
I washed it today getting off years of grime. Also replaced the air filter and changed the engine oil.
