Old 06-06-2023, 09:13 AM
gbenoit gbenoit is offline
Default 1772 with 50c (359)
Hello,
I tried to put belt on my mower deck on 1772 w/50C mower deck.
The belt is B90 Gates, supposed to be the good one for this set up.
Is too short all binder are in minimum position and mission maybe 3-4 inch to install the belt. Someone has this problem in the past? My mule linkage are OK ?
see picture
Old 06-06-2023, 09:31 AM
Inactive Member
The correct belt for your application is a 954-3006, which is a Section B belt x 93".
Old 06-06-2023, 10:05 AM
a gates b90 is supposed to be 93'' and ok to replace 954-3006 but I dont know why, is to short
Old 06-06-2023, 10:35 AM
Inactive Member
The OEM Part Number is correct for a 1772 w/50C (190-359-100) using a 190-361-100 Mule Drive, and that the Mule Drive and 50C deck are installed per OEM recommendations.
Old 06-06-2023, 12:51 PM
Is this a new purchase or have you owned the tractor for some time?
If not.
You may want to download the 50c deck manual to check if it is mounted correctly.
Up to 530 and counting...
Old 06-06-2023, 01:06 PM
Inactive Member
Here is a link to the 50C Owners Manual.... Manual
Old 06-06-2023, 03:59 PM
If not.
First time I put the mower deck on the tractor
Old 06-06-2023, 05:59 PM
Inactive Member
The 50C Mower Deck could have two different Mule Drives to operate the deck.
* 190-360-100 used on standard Garden Tractors
* 190-361-100 used on Super Garden Tractors.
The Mule Drive (or PTO) belt, varies with the Mule Drive being used.
Mule Drive Belt:
* 190-360-100 uses 954-3003A (Sec B x 89.5")
* 190-361-100 uses 954-3006 (Sec B x 93")
