Old 07-20-2023, 06:57 AM
Area Man Area Man is offline
I do have digital and analog multimeters. Not sure if my service manual has a wiring diagram, but I don't know that it's needed if there's a good Youtube video out there, or if someone here knows which color wires to check, etc.
I watched the alternator video - I think that's less likely, as I had only jumped it a handful of times, and a brand new battery didn't work.
Thanks for all the suggestions!
Old 07-20-2023, 08:06 AM
149Chris 149Chris is offline
There is a plug connector near the clutch. You could unplug that and run a jumper wire straight from the battery. I would use at least 16 gage wire and have temporary toggle switch so I could safely operate clutch sitting in the seat. This should isolate trouble to either the clutch or the tractor wiring/PTO switch.
