Old 12-23-2023, 05:53 PM
Woodbutcher Woodbutcher is offline
Default Coil is hot
Having an issue with the KT17 in my 782. I replaced my battery and when I connected the cable there was a small spark indicating something is drawing some power. Amp gauge also shows a discharge. But about 30 minutes later I placed my hand on the coil and found it to be hot.
So I am hoping someone has seen something like this and give me a direction to go.
Thanks
Old 12-23-2023, 08:39 PM
Maybe the points are closed?
Old 01-07-2024, 11:11 AM
Well
Nobody ...
So I went to the troubleshooting and service info area and found the manuals you all posted here. Thank you. A terrific source for answers.
I tested the coil and directed and the primary winding checked to spec but the secondary checked "open". As did the plug wires. I don't understand why that would be.
Condenser also checked out.
Points are clean.
I checked compression and had 90 psi on both cylinders. Not sure if this is a good number but it doesn't seem too low or uneven. I can check later after some run time to see if there is any change.
So after a lot of starter fluid and cranking we are now up and running. I've adjusted the main and idle screws to my satisfaction.
So after all that I did notice something while trying to get started. I had a tendency to leave the key in the run position after a failed cranking. So I'm leaning toward the "hot coil" issue to me leaving the key on.
Any seconds to that?
Old 01-07-2024, 11:42 AM
I second that motion, don't leave the key in the run position, as the points, when closed will heat up the coil and ruin it....
Up to 530 and counting...
Old 01-07-2024, 02:24 PM
Originally Posted by Woodbutcher View Post
Well
Nobody ...
Points are clean.
#90 compression is just fine,
These double breasted opposed twins are low compression engines.
Iffin yall in-sits on leaving the key on, ya gonna pony up a Benjamin and a jackson or two, for something new.
Old 01-07-2024, 11:26 PM
Ozcub's Avatar
Ozcub Ozcub is offline
If that machine has an Hour-meter it will also be ticking over
Oz
Old 01-09-2024, 08:24 AM
Eegads !! It's worse than I thought! I'll be more careful in the future ...
Thank you for the kind encouragement.
