Old 02-24-2024, 03:04 PM
chzuck chzuck is offline
Default Cub 147 PTO Clutch Screws
I just looked on a dealer site for IH-23025-R1 set screws for my 147 PTO clutch - $15.24, OUCH! Anyone make their own pointed set screws in a small lathe? The closest I could find on McMaster-Carr had a flat spot on the end. Looked liked they had stainless ones that are pointed. Anyone use these?
Old 02-24-2024, 03:08 PM
try here, I am sure they sell other sizes....
https://www.ebay.com/itm/25622632649...86dPiqimCmELA8
Old 02-24-2024, 05:40 PM
Dart1917 Dart1917 is offline
https://www.mcmaster.com/92695A305/
Old 02-24-2024, 06:23 PM
Thanks, I was just now looking at those. Look like they should work.
Old 02-25-2024, 02:44 PM
ironman's Avatar
ironman ironman is offline
I have not done this yet, but I think next time I re-install a PTO I will use stainless Allen set screws (both sets) to prevent rusting into the pulley.
In addition I'll use longer ones for the second set (jam screws) so that they protrude above the top of the hole to prevent the hole from filling up with crud.
Hopefully to make any subsequent removals much easier.
Anyones thoughts?
Old 02-25-2024, 03:40 PM
I thought I saw a puddy cat...
I know the threads do not go all the way to the top so crud will accumulate, try stuffing tin foil in the hole.
Old 02-25-2024, 03:54 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I've always thought anti-sieze would be a good barrier against rust and crud.
Plow blade
#2 Cart
QA36 snowthower
Old 02-25-2024, 03:57 PM
FWIW:
My experience with Settin' screws is they are hardened.
AND if they protrude out of the thread and are tight/rusted when one tries to loosen them, the hex will split open, and that is not a good thing.
And Stainless while rust resistant, is softer metal so the hex swells and strips.
Your mileage may vary.
Old 02-25-2024, 04:04 PM
As Gumby says that's a good point ol'e George
Old 02-25-2024, 10:12 PM
I did find the set screws on CCSpecialities for $4.
Tags
clutch, screws
