Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Rear Engine Rider & ZTR (RER)
Old 05-14-2024, 03:16 PM
bquinn50 bquinn50 is offline
Default Cub Cadet Zero Turn RZT50 26HP Briggs & Stratton
Its a Briggs and Stratton Intek Motor and it having idle issues in that for the first 10 minutes of mowing the motor speed sounds fine with the throttle control lever in the mowing position with and with out the blades engaged but after 10 minutes of mowing I turn the blades off and the motor is now running at a much higher RPM with the throttle control lever in the mowing position. It's overreving and if you back off the throttle control lever to the slowest position the motor is still running at a faster speed than it should be instead of very slow speed. I've done some internet searches but no luck yet.
Old 05-14-2024, 03:31 PM
CubDieselFan's Avatar
Sounds like you have a governor issue. Maybe it is out of adjustment because of a weak spring? How many hours?
Old 05-15-2024, 01:23 PM
Default Cub cadet RX50
I'll check the hours when I get home. Would it make sense to replace the springs and then do the adjustment or just try doing the adjustment first? I found a video which seems to explain the procedure.
Old 05-16-2024, 01:49 PM
Default Hours on mower
I checked the hours on the mower and its only 355 which seems low for what I believe is a 2010. Anyway, should I try the governor adjustment or replace the springs and then do it?
i've tried to find the service manual but no luck so far.
Old 05-17-2024, 12:16 PM
Old 05-17-2024, 12:18 PM
Default Governor issue
