Old 05-21-2024, 09:29 AM
chico2141 chico2141 is offline
Default Kurt
Just joined 5/20/24. Looks like a great site from all aspects. My first
CC was a 2006 LT50--still runs rather well !. I have it out in my barn
waiting for me to find time to put on new starter. In 2021 I bought an
XT1 LT46. I have a problem with the two front wheels "toe-out" I have
tried to find video on how to take apart and make adjustments to get them
back in proper alinement. ANY SUGGESTIONS ????
Thanks
Old 05-21-2024, 08:39 PM
spndncash spndncash is offline
I believe this steering system has two adjustable drag links that attach from each steering knuckle to the steering gear back at the operator station. they have adjustable ball joints screwed to the ends with a jam nut lock. if you remove the ball from the knuckle you can unscrew to lengthen (increasing toe out) or screw it further on to the link to shorten (moving towards toe in), be sure you leave equal threads engaged at each end of the drag link. Ild start with the steering wheel centered from lock to lock and then adjust to get your wheels straight and slightly toe in. the slop in bearings and ball joints will push it towards toe out naturally as you drive forward.
