I have a 1965 122 with manual lift and what I believe is the original 42" mower deck. On one notch of manual lift it cuts too low. On the next notch up, it cuts a bit.too high. Is there an adjustment I can make too the scissor lift mechanism (haven't a clue what the real name is) to tweak it enough for my needs?
I don't believe there is any cam adjustment that you can make to it. You could put a hydraulic lift or electric lift on that would give you slide adjustment with somewhat of an infinite range, limited by the extremes, of course. Have you inspected your teeth on your bracket to see if any are missing? You could also use the "float" adjustment for your deck if you want it to follow the contours of your land. You might even try mowing your grass in a different direction than you normally do to see if that makes it look better to you.
BTW: Great looking cub that you have there and welcome to the forum! Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Lock out the lift button and use the stop that is on top of the frame rail by your right foot.
Part #7 All it takes is a 3/4' wrench You will then gain the advantage of "deck float" as well |
![]() Quote:
That is exactly what I did on my 123 to work around the same problem the OP is having. |
That's what it's there for!
The notches on that ratchet bar (part #8) I'd guess move the deck 1/2 to 3/4 of an inch between notches.
I'm having trouble envisioning the o.p.'s problem of the cut being too low and then too high by moving the arm-strong lever just one notch. I wouldn't give it any thought, but maybe he's mowing a putting green. That being said, I have seen the slot at the bottom of the arm-strong lever (part #11) worn so bad that it lets the rod (part#6) rotate and not hold in position like it should, but regardless the chosen cut height would remain constant. |
I completely forgot about that stop. Thank you so much for reminding me.
Tags |
122, 42" mower deck, maual lift |
