982 no spark
I have a 982 with the original onan engine. I went to take it out of storage and it started for about 10 seconds then shut off. I sprayed a little starting fluid and it wouldn't fire. I checked for spark and there is none. Any Suggestions of where to start would be appreciated.
Thanks, Earl
Original, 1512, ih 982, ih 682 |
Believe that engine has points and condenser. Need 12 volts at the coil positive post with the key on
No voltage at coil
There are safety switches (seat, PTO, relay) and there's the key switch. You need to track to the point of break.
https://www.ccpartsnmore.com/cub-cad...ing-schematics Click the link and scroll down to the proper model for the wiring diagram.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Finally had time to look at it. There are 12 volts going to the coil. So i would guess that it would have to be the coil because that is the last thing before the spark plug besides the plug wires. Does that sound correct? Any way to test coil? IF i can find one im sure its going to be expensive and i would like to be sure before i buy it.
Here is the free manual from our Tech Section. Look on page 3-9 for testing.
https://www.onlycubcadets.net/forum/...ead.php?t=4661 New coil. https://onanparts.com/index.php?main...roducts_id=146 And of course the Scamazon crap. https://www.amazon.com/s?k=166-0772+...l_7zyef7rt63_e
Well , you also need the points to make contact to trigger the spark discharge through the plug. Have you cleaned the points? I'd surely do that before replacing a coil, since it's free to do.
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
I tested the coil as the manual showed noticed a plug wire was not snapped down on the plug. Put it back together and it fired up ???. I would think it would have at least fired on one plug. Its working and i guess thats all that matters. I appreciate everyones help
Thanks, Earl
