Old 09-27-2024, 03:05 PM
Bob Handy Bob Handy is offline
Default 2166 hard to start - adjust carb choke plate!
I have a 2166 that has been hard to start for a long time. It turns over, but takes a while to start. Once started, it ran great.
From sources like this forum I tried lots of things:
> Checked spark- looked good
> Checked fuel flow - fuel pulses out of the filter when turning over
> Checked choke linkage - fully closing
> Cleaned carb
It would still take 10-20 seconds to start.
Then I noticed the kohler carb rebuild instructions included a short section on adjusting the choke plate.
'To align choke plate, insert a 0.010 in. shim between the top right edge of the choke plate and bore.'
I loosened the carb choke plate screws, adjusted the choke plate and re-tightened. It starts much quicker now!!
This adjustment solved a nagging slow to start issue for me.
Maybe this could help someone else with a kohler that is slow to start.
Old 09-27-2024, 09:35 PM
CubDieselFan's Avatar
That is good info for someone. Thanks for posting that Bob.
