Old 09-28-2024, 10:43 AM
Merkman Merkman is offline
Default Barn Find 09 GT2544.......ovedue maintenance!
Hello
Just "barn" find... An 09 GT2544 with 42 hours on it... Been parked in garage for 15 yrs... oils are clear, like new. I've greased what I could. Some points would not accept grease...like the lower steering point...zerk was clear but still wouldn't take the grease...fixable?
What else should I do to it? Change the fluids and filters?
Thanks.
Old 09-28-2024, 11:53 AM
Billy-O's Avatar
Billy-O Billy-O is online now
Better safe than sorry thoughts... change 'em.
Plow blade
#2 Cart
QA36 snowthower
Old 09-28-2024, 01:13 PM
ironman's Avatar
ironman ironman is offline
That grease fitting is pressed in.
If you can pry it out, new ones are available.
Part #937-3000
Old 09-28-2024, 05:32 PM
The lower steering fitting was threaded, I took it out and its accepting grease no problem. whatever is behind that fitting is clogged with old grease, maybe. The fittings on the steering pins are pressed in and one is missing... perhaps part 937-3000, will look into fixing that...Thanks...
Old 09-28-2024, 07:10 PM
Ozcub's Avatar
Ozcub Ozcub is offline
By lower fitting do you mean the one behind the engine or the one underneath next to the gear segment ?
If memories serves correct there is 11 grease nipples (zerks)
Also half way down the steering shaft behind dash panel is another point to lube
Change all fluids
Oz
