Old 09-28-2024, 10:17 PM
Farmall450's Avatar
Originally Posted by Farmall450 View Post
All was well after some new plug wires. I did put on the 3 point and mowed a bit more. It's ready for winter now - needs some more hard use and possible carb work/adjustments (hunts when cold) in the spring.
Does anyone see anything wrong with the 3 point in this picture? I just saw it the other week petting the cat. Attached photo shows it after I corrected it - tons of the ones online are wrong, too!
Old 09-29-2024, 09:42 AM
I've seen a lot of them with the sway eliminator cams on bass ackwards.
They were on upside down AND bass ackwards in post #15.
You can tell by the paint on the drawbar support plate.
Old 09-29-2024, 10:31 AM
Farmall450's Avatar
Good eye! I was petting my cat on the ground and happened to look up and see that.
Funny thing is I googled 982 3 point to see how it should be and most of the ones online have the right side on wrong, like mine was. I wonder if the dealer instructions were messed up. The parts catalog shows it correctly.
Old 09-29-2024, 12:55 PM
You going to bring it to Steve's big plow day in 3 weeks?
Old 10-01-2024, 12:11 PM
Farmall450's Avatar
Where/when is that? I'd probably take my 782, that has ag tires and a sleeve hitch.
Old 10-01-2024, 01:20 PM
Roanoke, IL
Oct 18-19
Parade Lap at noon on Sat
