Old 09-18-2024, 03:16 PM
PolCadet PolCadet is offline
Default GT2100 does not recharge the battery.
Hello.
GT2100 (2011) 280 hours.
I checked the two wires coming from the stator with multimeter. When the motor is off, there are 4.8 ohms coming from the stator and when the motor is running there is no voltage coming from the stator. Does this conclude that the stator is defective without a doubt?
Any help is welcome !
Old 09-18-2024, 05:13 PM
Sam Mac Sam Mac is online now
This should answer your questions
https://www.onlycubcadets.net/forum/showthread.php?t=32
Old 09-18-2024, 08:05 PM
ironman's Avatar
ironman ironman is offline
The output from the stator is A.C.
Make sure your meter setting is on A.C.
Old 09-24-2024, 06:44 PM
Default Positive or Negative ?
Thanks fo reply !
One of the two wires that come from the stator is WHITE and the other is BLUE. Is there a positive and a negative?
Old 09-25-2024, 10:33 AM
AC is alternating current so no positive or negitive
Old 09-26-2024, 06:51 PM
The image on the right shows that the voltage coming from the stator is in A.C. The image on the left shows 28+ V.A.C. entering the voltage regulator. How much voltage is enough from the stator to know if it is in good condition?
Old 09-30-2024, 05:15 PM
You should have at least 28 volts AC at 3600 RPM. If you don't have that then you have an issue with the stator or flywheel magnets.
