GT 2100 -> Damaged fuse
Hello.
In the fuse box, someone can describe me or refer me to a WEB link to find out the reference of each fuse. I am making this request because a 30 fuse has been damaged, seems to have heated up. What can be the cause of damage ? Cub Cadet Fuse.jpg Thanks for reply ! |
Dirty and/or corroded terminals or wiring in general.
Cruddy wires & such causes high resistance and related heat. Plastic does not like heat. |
Agree totally, corrosion is not your friend.
If you are asking, those fuses are auto parts store items. |
I need Lucy to splain to me...
high current causes heat....heat melts plastic corrosion causes high resistance..... high resistance reduces current.... how do corrosion make fuse melt??? |
Corrosion allows arcing, and that makes heat.
Just like a loose Bat- tree terminal. |
