Old 10-20-2024, 09:16 PM
garydee's Avatar
garydee garydee is offline
Default Kohler CH18 enging running rough
My 1864 has been acting up lately...lacking power. I checked both spark plugs (just put in new autolite plugs) two weeks ago, changed oil to get ready for leaf season etc.
Today, I tried starting the engine with the right plug wire pulled. It seemed to run ok, but not normal at low idle. Then, I pulled the left plug wire, (reconnecting the right) and tried to start it again. No such luck. No start.
I'm guessing that the ignition coil for the right cylinder is the problem. Is it possible that the coil is open. The engine seemed to be running hotter than usual the last time I mowed. Could that have caused the problem?
Any recommendations on where to order coils from? (if that is the problem)
Help is appreciated!
Old 10-21-2024, 08:22 AM
dale c. dale c. is offline
first check for spark , second check for compression, and report back with what you find
Old 10-25-2024, 10:41 AM
garydee's Avatar
Default CH18
Checked for spark...good. Checked for stuck valve...good. Compression test...good. Checked conductivity of spark plugs...NOT GOOD!
I installed 2 Autolite plugs a few weeks ago. They worked the next time I cut the lawn. Did not work the last time. I have had trouble in the past with non-conductive Autolite brand (from Walmart) plugs..seems I haven't learned my lesson about using cheap plugs.
The apparent problem is that the top of the plug is "non-conductive" where the boot wire attaches. Tested with a continuity tester to determine this. Removed coating with a wire wheel and reconnected. Started right up, smooth idle and plenty of power at high RPM.
So I got things workin' but I want to find a better quality set of plugs that will do the job. I believe the originals were Champion RC12YC which may not be the best for the engine. Does anyone have a solid performer that will make the engine run well? Anything from NGK or other brands?
Your thoughts are very much appreciated!!
