Old 10-26-2024, 07:19 PM
IHCubCadet147's Avatar
Default 1440 PTO clicks but does not engage
The bearing in the PTO on my 1440 went bad, so I ordered a used PTO off eBay. I put it on, and went to test it and it worked for about 30 seconds then stopped like I shut off the switch. Now with the tractor off, I can hear it click when I flip the switch, but the PTO does not engage with the tractor running. I adjusted the air gap to .017. The PO bypassed the original PTO switch and added another one. Just a simple on off switch with power coming from the battery, so no safety switches. It has worked fine like this for the 2 years I’ve had this tractor so I don’t think that’s the problem. It is getting 12 volts at the pto, and it is grounded. Did I get a bad PTO or what? I can send it back and get a different one, but want some opinions first.
Old 10-26-2024, 09:44 PM
If you have 12 volts at the PTO and it doesn't engage I'd say it's bad.
https://www.google.com/search?client...1-d&q=917-3389
I've had good luck with these PTO's
https://xtremeope.com/p/xtreme-repla...det-717-3389p/
Old 10-28-2024, 09:35 AM
Thanks Sam. I’ll send it back and get a different one. I hear a lot of good about those Extreme ones, but I don’t want to spend that much money on this tractor. It’s junk, and to me not worth the work it needs to make it nice. I just want to get another year or two out if it. I’ll try another used one.
Old 10-28-2024, 02:48 PM
Billy-O's Avatar
Billy-O Billy-O is offline
If it will help any, recheck your connections at the PTO. While you mentioned you have 12v at the PTO and it is grounded, sometimes the contact/connection points might be compromised (example: dirty, paint on connection surface, etc.) that it's enough to render the PTO inoperable even if it worked for a moment.
Otherwise, just like others say, return the PTO for replacement.5
Plow blade
#2 Cart
QA36 snowthower
Old 10-29-2024, 09:00 AM
Originally Posted by Billy-O View Post
If it will help any, recheck your connections at the PTO. While you mentioned you have 12v at the PTO and it is grounded, sometimes the contact/connection points might be comprised (example: dirty, paint on connection surface, etc.) that it's enough to render the PTO inoperable even if it worked for a moment.
Good point, I didn’t think about that. I know the connections on the tractor side are clean, but I never checked the ones on the PTO side.
Old 11-04-2024, 08:13 AM
It was a bad PTO. My new one came in and I put it on and it worked perfectly. I put about 5 hours on it over the weekend with no issues. And the best part, this one was actually $15 cheaper than the first one.
Old 11-04-2024, 09:27 AM
Glad all is well and you let us know.
Old 11-06-2024, 09:12 AM
Thanks George. I hate it when someone asks a question and never comes back to post the outcome.
