Old 11-08-2024, 03:10 PM
Road_Clam Road_Clam is offline
Default New member , need some purchase guidance
Hello everyone ! I really need some advice on a CC purchase. I beat the crap out of a Craftsman 42" single cyl as my property is about 1.5 acre and .88 acre of uneven grass terrain. I also need the possible option of adding a snowblower in the future. Lastly looking to tow a cart hauling rocks / small logs. Im looking at buying a new XT2 GX54D model as i really like the K61 trans with the diff lock option. Only problem is a 54" deck is going to be an issue (too wide ) scalping my lawn . Im concerned that if i step down to a 46 or 48 the K46 trans will not hold up to my needs (especially with a snowblower as my driveway is a slight hill ). Given these circumstances what would you guys suggest for a model ? I also have a really clean used 2020 XT1 ST54 for sale close to me and contemplating over buying it but it only has the K46 transmission and i'm hearing there's lots of issues with the K46 if it gets abused and not fluid changed. Thanks in advance for your input !
Old 11-12-2024, 10:53 AM
Sergeant's Avatar
Sergeant Sergeant is online now
The XT2 GX54 D has a K62 with steel Cut Gears, it Only has 93 pounds less torque than the K66. I haven't had an issue with a 54-inch Cub Fabricated Deck scalping, But I have a Cub Cadet XT3 GSX and a Cub Cadet SX54 Zero turn (steering wheel control).
My wife and I Bought an XT2 GX54 D for a friend of ours In 2017; it Has 1,000 plus hours On it Now Again he Has had no issues scalping Lawns, and He Mows's (22) 1/2acre & 3/4acre Yards On top of his Own 3/4 acre Yard
You can actually refill the K62 through the Battery compartment, and it does have drain Plugs Unlike the K46 or TL-200 (TL-200 used in XT1 series Lawn tractors with a 46-inch deck or smaller)
The XT2 GX50 has a Non-serviceable K58, and so does the XT1 GT54. John Deere Uses the K58 In the X380, X384, X390 and X394 Lawn tractors.
BTW, the Craftsman T4400 is basically the same as an XT2 GX54 D, except it has a Kawasaki engine and a Tighter Turn radius. IT also has Diff/lock and a K62 with Steel Cut Gears https://www.craftsman.com/collection.../cm14aha6zma93 so it is a slight upgrade over the standard XT2 GX54 D
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 11-12-2024, 12:06 PM
Thanks for the awesome detailed info ! Ended up buying the GX54D. Heavy duty enough to handle my potential additional needs moving fwd.
Old 11-12-2024, 08:00 PM
Sergeant's Avatar
It should serve You well and there warranty really is a Bumper to Bumper for 3 years
Old 11-13-2024, 09:16 AM
Thanks ! I have a long history of deep wrenching knowledge as ive done 3 nut and bolt motorcycle restorations. Trade school graduate , and been wrenching all my vehicles for the past 41 years . Can also do fabrication. After a very close accessment of these newer CC platforms is you need to clearly understand the limitations (fundamentally with the chassis) . I can see how guys get into trouble when slapping cheap universal hitches to the rear and expecting expecting to pull heavy loads with heavy tongue weights. My dealer told me that the 54D can pull 3000# (rolling) on flat ground. I was thinking maybe some light garden implements but after chassis considerations im not going that route. Going to tow around a 4X8 utility trailer and thats the limits. Possibly a snowblower in the future.
