Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Rear Engine Rider & ZTR (RER)
Old 03-15-2025, 01:02 PM
bgm1961 bgm1961 is offline
Default Are ZTs typically delivered with over-inflated tires?
I just took delivery of a ZT1 50" from Home Depot. They did a good job of assembling the mower in accordance with the manual. But when I checked the rear tire pressure, each was over-inflated to 25 PSI. Is that typical???
Background since I'm new here:
After renting apartments and houses with small yards for the past 30 years due to constant moving around with the military, this past fall, I purchased my final "settling down" house. It has a lawn which needs a riding mower, for which a ZT is the most appropriate machine for the job. While the ZT1 42" is perfectly suitable, I went with the ZT1 50" for its Fab deck, higher HP engine, and wider tires. Also, I purchased from Home Depot only for my military discount. (And yes, I'm aware of the benefits of purchasing from a dealer. Perhaps I'll start another thread on that topic).
Back to the topic (sorry, this turned out to be a narrative):
Honestly, I never checked the tire pressure before test-driving it. The only place that tire pressure is mentioned in either of the manual's Safety, Setup, or Operations chapters is in the "Setting Deck Wheels" step. And that's the only step I skipped while ensuring that Home Depot setup the mower correctly! I skipped it as I want to level the deck first, after which I'll check the height of the deck wheels. Plus, I didn't plan to lower the deck while driving it in the driveway.
So, I skipped that one step. As such, I overlooked checking the tire pressure. Also, the tires just "felt and looked" right for how a tire should feel to me. And yeah, there was a bit of an assumption that since HD got everything else correct with the setup, then the tires ought to be good, also. Though that wasn't an active thought, it's my excuse for why I didn't check the pressure before "taking her out" for the first time.
(By the way, the mower ran and drove like a dream (though the YouTube videos are correct about how loud it is). The ZT steering/maneuvering of course will have its learning curve, but all is exactly what I expected).
Anyway, the next day, before taking it out again around the driveway (I have a good-sized driveway), it occurred to me to check the tire pressure, "just to see how close it was to the requirement".
The first thing I read on the tire's sidewall was a warning to not exceed 35 PSI. "Okay, I said to myself, that seems right".
As such, I was expecting the requirement to be around 30 PSI, or something like that... especially given that's how the tires felt.
But when I found the "Max Inflate to" specification, I had to go get my reading glasses to make sure I was reading it correctly.
"Huh?"
"Ten PSI???? Really"
"Only ten???"
That was my reaction. It was especially so when my pressure gauge showed they were at 25 PSI!!!
So, a quick Google search of proper tire pressure for CC ZT1s (plus almost all zero turns), is that the rear tires are indeed supposed to be at 10 PSI!
Learn sumthin' new everyday.
So then, why did Home Depot deliver the tires at 25 PSI. Is that typical?
Old 03-15-2025, 01:35 PM
CubDieselFan's Avatar
Thanks you for your service to us in the military.
Yep, pretty typical. You are ready know how we feel about buying from HD and not a dealer so I will not give you a hard time about that.
Pretty much, some one at the store put that mower together and was just looking to get it done and done fast. I would question everything and make sure it is done properly. The 25 PSI would have not hurt it any I think. Would have made it ride rough. 10 Psi would make it ride better but you will still feel bumps in my experience with ZTR's.
Old 03-15-2025, 01:44 PM
Sergeant's Avatar
Sergeant Sergeant is offline
Yes, they are overinflated before they are loaded into a shipping crate. The Problem is, at least with Cub Cadet, the box store does the set-Up. With John Deere at a box store, a Local dealer does the set-up on a Deere's sold at a box store.
In the 21 years I was In the Army, I was moving a John Deere Garden tractor and an Ingersoll Garden tractor with Tiller, snow thrower and front Blade for the Last 14 years I was In, But we usually rented off Post. In my final Move Back to Illinois, I had to ship 3 Garden tractors, Including Two with Front end Loaders.
Old 03-15-2025, 08:03 PM
Originally Posted by CubDieselFan View Post
...some one at the store put that mower together and was just looking to get it done and done fast. I would question everything and make sure it is done properly.
Yes, that was my expectation as well, which is why I thoroughly examined the final assembly. Putting aside the tire pressure matter, they did a good job.
Thanks for that opinion. Given how much it was over-inflated, I was worried that the little bit of operating I did with it on the driveway may've increased the potential of a problem with the tire/wheel assembly later on.
Though, the more I think about it, the more I conclude that when on the driveway, an over-inflated tire is exactly what I want to help preserve the transmission. And when on the grass, keeping the tires at the proper PSI will help preserve the grass!
Old 03-15-2025, 08:12 PM
Good to know.
Thanks!
And that's very interesting to know! Still, even with that knowledge, I would've still stuck with the cub, given all the research I've done and my budget.
In the 21 years I was In the Army, I was moving...
Those were good years, I bet! (I enjoyed mine, anyway). I spent almost all my years either living on base (small yards, little room to keep such equipment), or renting houses (didn't purchase such equipment due to uncertainly of next assignment), or living in apartments. So, this is my first foray into a riding mowers and other large equipment which a homeowner buys!
Old 03-15-2025, 08:38 PM
I thought of making a separate thread out of this matter, but I'm sure it would be a pretty quick conversation. So, might as well discuss it here for now...
I think I understand the benefits of purchasing from a dealer. And if it wasn't for my military discount at HD, I would have. But it seems to me that many people put a much higher value on those benefits than I would.
Let's see what I think those benefits are:
"When you buy a mower from us, we'll make sure it's assembled correctly and we’ll take care of you when you bring it in for servicing".
Am I missing any other benefit which a dealer provides? (Seriously). If not, then:
Since HD also assembled it correctly (aside from the tire pressure), that particular benefit is a wash.
Thus, the primary benefit of purchasing from a dealer is the "We'll take care of you" benefit. Still, as this is a highly intangible and uncertain benefit, it's really hard to put a monetary value on it.
So, what does it really mean for a dealer to take care of their customers?
- Preferential priority when bringing-in a mower for servicing? Yes.
- Discounts on parts? Perhaps.
- Servicing packages which only come with a purchase from them? Perhaps.
I may be overlooking another benefit. If I am, please let me know as I've never purchased a mower from a dealer. So, if I’m correct above, here's what I’m thinking:
- The warranty on my Cub Cadet is a manufacturer’s warranty, is it not? Thus, if I have an issue during the warranty period, then I should be able to bring the mower (that I purchased from Home Depot) to a local dealer for the warranty work. Or am I sorely mistaken?
I get that the dealer will frown upon it being a HD purchase, and as such, my mower will likely get put at the end of the line. They may prioritize taking time off for a shop picnic over servicing my mower. And they may order any needed parts on a low priority basis, etc, etc. I get all that. But still, the warranty work WILL get done, correct?
With my 10% discount on the $3,599 price, and factoring-in a 9.5% sales tax, I saved $395 by purchasing from Home Depot. For that savings, I can accept having my repair work by the local dealer pushed to the back of their priority list. Especially since I intend on doing all the regular maintenance myself.
The point of this post is to share how I see things, so that I can tap on your experience to help me understand what I may be overlooking! I mean, it’s not like a dealer will purposely do shoddy work just because it’s a Home Depot purchase, right? At least I hope not.
Old 03-15-2025, 09:15 PM
Sergeant's Avatar
Originally Posted by bgm1961 View Post
Good to know.
Thanks!
My Army Career by Post: Fort Bragg, Fort Drum, Fort Bragg, Fort Devens, Fort Bragg, Fort Benning, Fort Leonard Wood, Fort Bragg, Fort Drum, Fort Bragg, Fort Drum retired My whole Career was Light Infantry in one form or another. I only Left the US for Operations Urgent Fury , Just Cause, Restore Hope, Uphold Democracy Enduring freedom and was In the Sinai as well I then worked as a Civilian Military advisor for Uncle Sam for another 12 years on and off
The Wife made me put in for retirement when I got selected for Sergeant Major, as She didn't want to move again. She was tired of being a camp follower.
Old 03-15-2025, 09:36 PM
Good points, pretty much covered everything. I agree, most shops will not do a bad job if you did not buy it there. The problem in my experience is if there is a problem, with a covered warranty issue. The hassle factor. No servicing dealers in my area for Cubs anymore so I would probably never buy a new one. I would just buy another old one and work on it.
An example of what my son just went though with a Whirlpool dryer from Lowes. New dryer delivered November last year. Broke the first week. 2 weeks later the dryer was fixed. Broke again the next day. They said, 3-6 weeks before we can come back. They went to a local appliance dealer in our hometown. Mom and Pop type place. Bought a new dryer and they were talking about the old one. They offered to pick it up and see what was wrong. Picked it up when they brought out the new dryer. Fixed the old Lowes dryer and covered the cost under warranty and took it back to their house. Better chance of getting good service with a local shop/dealer than a big box store.
Old 03-15-2025, 09:47 PM
Sergeant's Avatar
You are correct On warranty work and your possible Position in Line for service. Some dealers will do that, and some won't put You at the end of the Line. My Local Cub dealer Puts You In Line that he got the Call. But I did buy a Cub Zero turn from him in 2022. This Fall through spring, so far he has worked On 3 Cub Cadets of Mine that he did not sell to me. But I am in no hurry on their repairs.
As I have so Many Machines
I do as Much as I can Myself when You Have as Many machines as I do
Cub Cadet Original
Cub Cadet 60
Cub Cadet 70
Cub Cadet 106
Cub Cadet 1450
Cub Cadet 2182
Cub Cadet 3208
Cub Cadet XT3 GSX
Cub Cadet Z-Force SX54
Ingersoll 3016PS
John Deere 110RF
John Deere 112SF
John Deere 140H3
John Deere GX335
John Deere X748
John Deere Sabre 1542 HS
Simplicity Wonder-Boy
Wheel Horse 416H
White GT2055
John Deere 2025R TLB
My Local Cub dealer I have Know since Before I retired from the Army as they worked on stuff for My parents
The Deere dealer I use, I Know Many that work there Personally Because My Younger Brother worked for them after He got off of the Army. So I cart My John Deere's 60 Miles so only they work On my Deere Machines.
I just think it's better to establish a relationship with a dealer, and the Best way is sometimes to Purchase from said dealer instead of a box store. I know when My Cub or Deere dealer sees me, they probably roll their eyes Because they are Probably saying, What did he bring us now to work on? But they Know I pay my bills with them. And they do go the extra Mile and fix the Old stuff. Find parts that are No Longer available that may be from a boneyard. They don't go; it's No Longer Made, say we can't fix it.
Old 03-16-2025, 10:30 AM
Farmall450's Avatar
I'd bet most lawn tractors & ztrs out there are running around with over inflated tires.
Tags
home depot, pressure, tire pressure, tires
