Old 06-11-2025, 04:43 PM
CVACUB CVACUB is offline
Default Wiring harness replacement
So I picked up a 122 IH Cub Cadet. I was told by the previous owner it’s a 1969
I need a complete new wire harness with battery leads included since mice,birds and god knows what else has lived in it. Can anyone recommend member recommend either a member or a company that can assist me with this. I’ve checked the plate on the rear pumpkin and it’s been painted over so I don’t know what the serial number is
Thanks in advance and I’ll post pictures of the CC
Old 06-11-2025, 04:46 PM
Default Additional pictures
Can I post more than one picture at a time?
Old 06-11-2025, 04:52 PM
CubDieselFan's Avatar
Yes sir, you can.
Old 06-11-2025, 04:55 PM
Here is some reading on harnesses.
https://www.onlycubcadets.net/forum/...ad.php?t=14670
Old 06-11-2025, 07:19 PM
Thanks I just messaged Mike
Old 06-12-2025, 05:35 AM
I have heard great things about Mike too. There is also another member that makes harnesses IIRC. Here is his link.https://solunagarage.com/
Old 06-12-2025, 08:19 AM
Graflex45's Avatar
Graflex45 Graflex45 is offline
I recommend Brillman company, they are in VA so it will get to you quick. I got a model 70 harness and it looks just like factory, except better because they solder all the lugs for permeance.
https://brillman.com/product/ihc-cub...-wire-harness/
Double check this is the right part for your model.
From the pictures it looks like your tractors clutch and driveshaft cover is missing, puts the spinny bits dangerously close to the harness. if you cant find that cover for cheap I definitely recommend finding a wide enough piece of sheet aluminum and bending it to make a driveshaft cover.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller
70- 38in deck, 42 inch deck
