Closed Thread
Old 04-13-2026, 01:06 AM
Sergeant's Avatar
Sergeant Sergeant is offline
Originally Posted by CubbaCudet View Post
Thanks for the information. VERY helpful. Isn't it strange though that its not mounted? The engineers literally had to say, "Nah, don't mount the container holding flammable liquids that is only 4 inches from a hot engine."
I heard the Cub Cadet XT2 GX54D is literally the same as the Craftsman T4400, just with minor differences. I wonder if the Cub Cadet would also have a floating gas tank? Now that would be fun research.
MTD/Stanley is the Parent of Cub Cadet and Craftsman
The only differences besides paint color are the front axle and steering arms on the Craftsman, so you have a tight 6-inch turning radius, and the Craftsman has a Kawasaki and not a Kohler engine.
The XT2 GX54 D has the same gas tank setup, i.e., no strap to hold the tank. The tank neck and fuel hold the tank in place.
Old 04-14-2026, 07:23 AM
Road_Clam Road_Clam is offline
Another vote for "dont lube the steering pinion gears" on my Cub GX54D. I tried grease thinking this would help , it worked awesome until debris got all jammed in the gears with the grease. Ive done quite a few mods on my 54D , my top suggestion is to add a dedicated ground wire from the battery / frame mount to the engine block. Cubs are notorious for electrical problems and its my conclusion that its from poor grounding and moisture . I also added dielectric grease to all the electrical connections .
Old 04-14-2026, 08:07 AM
I suggest that you find a Craftsman forum or join My Tractor Forum to find info about your mower, this forum is for Cub Cadets and Cub Cadet related issues. This post is now closed.
Closed Thread
Tags
craftsman, loose parts, poor instalation, t4400
