Old 04-25-2011, 06:59 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default still to much juice at the points
heys guys, i've done searches for the answer to this question and still no answer, so i'm gonna throw it out for ya'll. i am having a problem with to much juice at the points. i have rewired the tractor from the VR back as per the wiring diagram from the tech section on here. i know the VR, coil, points, condensor, S/G are good BUT when you turn the key on to try and fire it up, it get's so hot at the points that it melts the plastic thus ruining the points. i'm at wits end here so ALL answers will be GREATLY appreciated!!!! i am sorry for being so annoying, but i've tried and checked everything i can think of. thanks, jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 04-25-2011, 07:09 PM
mmzullo mmzullo is offline
You have the wrong coil in it. It should have an internal resister coil. Only 6 volts to the points.
Old 04-25-2011, 07:18 PM
The points will only get the Value of the Voltage from the Battery, NOTHING more.
If you are melting the plastic insulator on the points......you have too much AMPERAGE DRAW or LOAD on that circuit.
jeffscub's Avatar
ok, that makes some sense, i really don't understand it, but..... is that why there was a ceramic type piece that was zip tied to the coil? there were no wires connected to it when i got it, and i got it to run great till the carb started leaking WAY bad without it being connected. thank you very much!!!! jeff
Jeff
Old 04-25-2011, 07:24 PM
jeffscub's Avatar
so is what mmzullo said the possible reasoning behind my trouble? i went back and cleaned the leads with a dremel and found the letters stamped on them and went back and wired it correctly, i even triple checked my self and had my dad come back behind me and check. so i know everything is correct. i'm only gonna take so much aggravation from the 100 and "BAM" it's gonna be for sale!!!! thanks Mr. Bedell jeff
Jeff
Old 04-25-2011, 08:31 PM
All my Kohler Ignition Coils are 12 Volts.
If you have it wired correctly and if you have the correct parts on your ignition system, then you will have NO problems.
Old 04-25-2011, 08:37 PM
william1041200's Avatar
I once tried a high performance coil that was not internal resistor, and was that not bad enough, left ignition on upon quitting working on a non running tractor. Came back next morning and battery was dead. Thunk on it a while during the day, with battery on charge (out of tractor) Then I went to hook battery up, and got a BIG ARC. Hooked up positive leads and grounded to metal to see what was up, and found points lead smoking. checked points next and points were fried. So was coil. Lucky was I that battery was weak, and died quick.
Old 04-25-2011, 10:04 PM
Southtowns27's Avatar
Either you have a non-internal resistor coil, the coil is shorted, the condenser is shorted, or the wire from the points to the coil is shorted. It can ONLY be those things to be causing your problem. Should help narrow it down for you. If it were me, I'd go buy a new correct coil and condenser, change the points, and the wire from them to the coil. It could probably use it anyway, and it'll fix your problem
Old 04-26-2011, 10:12 AM
APPALACHIAN EDGE's Avatar
APPALACHIAN EDGE APPALACHIAN EDGE is offline
I had the same problem one & learned the hard way. I had the wrong coil ! Get the right one & replace condenser & points & youll be fine! You can get them to run on the others but points don’t last long & your engine will run hot! Hold your coil wire about an inch away from your spark plug itl Start & run, that’s a definite sign it’s too hot a coil !
I won't be wronged, I won't be insulted & I won't be made a fool of !
I don't do these things to others & I require the same from them !!
Old 04-26-2011, 10:52 AM
shouldwe's Avatar
shouldwe shouldwe is offline
Default coil
I would check your condenser and check all your grounds, check it with a meter. I would check the values on the primary and secondary windings of the coil. You can find them in the OCC library make sure the points have ground.
Have you driven a cub lately
