I have a 1650 and a 1450. I'd like to pull the 1650 out of service for a refurb and use the 1450 for mowing this season. The 1450 had a #52 Walbro carb on it. I'm about ready to put the 1450 back together and I was thinking of pulling the Carter #30 carb from the 1650 and putting it on the 1450, then buying another Carter prior to putting the 1650 back together.
Will the Carter #30 bolt right up and run correctly on the 1450? Will the linkage work the same, or do I need to move anything else over when move the Carter? Thanks for any advice, -Calvin |
Should work just fine... The #30 carbs were for the 14 and 16 hp motors.
