Old 06-28-2011, 01:17 AM
Cub 61 Cub 61 is offline
Default Hydraulic Cylinder
I was moving some dirt this weekend and when my blade is down and i go over a mound of dirt or a high spot the blade raises and pushes the cylinder back to retracted position. Is this suposed to happen? If not, what do I do? Thanks.
Old 06-28-2011, 08:46 AM
mmzullo mmzullo is offline
First What piston? Aux lift, hydro lift? Neither should. If it's a aux hydro lift are you sure the rock shaft is not riding back up? If it's a on board hydro lift do you have a lock out pin installed?
Old 06-28-2011, 09:15 AM
If it's the lift cylinder you are talking about, it's just the rockshaft floating. You need to install the float lockout pin or bolt (depending on what model tractor you have) so that the blade has down pressure for moving dirt.
Old 06-28-2011, 12:20 PM
I have a 149, wherecould I get the pin or bolt, and how do I install it?
Old 06-28-2011, 12:34 PM
Check this out for the float lock out pin:
http://ccmanuals.info/pdf/Float%20Lo...%20Install.pdf
Old 06-28-2011, 01:28 PM
I got it figured out. Thanks for all the help guys. When I use my plow, tiller, and disk do I/ have to change it back so it can float?
Old 06-28-2011, 01:59 PM
I tried it out with the lock pin in and it is still floating.
Old 06-28-2011, 03:31 PM
Yes you do...
Anyway of getting us some pictures of the float pin setup and your blade setup?
Old 06-28-2011, 03:58 PM
Here is a pic of the lock pin in.
Old 06-28-2011, 08:56 PM
Very carefully operate it without the tunnel cover as you were and see if it's actually the cylinder or something else. It may be that you have a broken spirol pin in the rockshaft but it's hard to tell without seeing what's going on.
