Old 01-13-2014, 07:43 PM
Mike
I can think of a few things I'd rather practice doing, LOL.
I'm with ya Sam!
Old 01-13-2014, 10:06 PM
Keep up the good work, Sam! Thanks for the pics.
Old 01-13-2014, 10:54 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Jon
I doubt that a vent at the top would do much. Any condensation will go to the bottom anyway.
I thought the condensation gets magically suspended in the Hytran
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-14-2014, 07:07 AM
Yep it does, then it settles to the bottom of the case. Only problem is the axel tubes trap it because there is no way to drain them. That's why when I have one apart I drill return holes in the bottom of the case to allow it to drain back into the center section. This one had globs about the size of large marbles in the tubes.
Old 01-14-2014, 05:34 PM
Finished up the rear end today and put the fender pan and seat back on. I also replaced the factory vent with a hose and filter. Test run went well, no leaks or funky noises. Not much more to do other than putting the floor boards and rear cover plate on. I'm waiting for the new rear wheels and tires from Xtreme and that will just about finish the tractor. Then I need to give the deck a little TLC.
Old 01-14-2014, 05:57 PM
jimbob200521's Avatar
You do some good work, sir, looks great!
-Ryan
Old 01-14-2014, 06:03 PM
Thanks for the comments but this one will be a worker at least for the upcoming season. Then as long as it is all good in the running department it may get a nice repaint job.
Old 01-14-2014, 06:13 PM
CTRUEX CTRUEX is offline
Woody
The rotors are OEM. The Cyclops supers have them, not sure about the older Supers. No idea why they did that. Not like they get hot.
Must have been the later Cyclops supers, my early 2082 has the grandma rotors. I feel the need for some race car rotors, maybe vented, as well. Does Brembo sell a kit for our Cubs?
Old 01-14-2014, 06:21 PM
Looks good Sam. You need to bring that one and your custom NF tractor down to Vince's Plowday this spring.
Old 01-14-2014, 06:55 PM
The 1782 is going to have an easy life, all it is going to do is kill grass fast. No plow days for it.
