Old 03-10-2016, 06:47 AM
Steve
I think I have a lift frame for a Haban in my stash of used parts. If I do and if it's better than what you have you can have it. Just cover the shipping.
Old 03-10-2016, 12:04 PM
Dirty Steve's Avatar
Great offer, Sam. Thank you. I have mine welded up pretty good at this point. But I will certainly keep it in mind.
Old 03-10-2016, 02:32 PM
This what I have if you need it.
Old 03-13-2016, 03:15 PM
Finally back in the shop today. Giving this machine a lift. And some color to it.
Old 03-13-2016, 04:33 PM
And then IH White.
Old 03-19-2016, 01:14 PM
Made it back into the shop to work on this Cub. The wiring has been giving me some trouble. Finally found a push in terminal with a bad wire crimp. The wire was added for the relay upgrade. It made it outside under it's own power!!!!
The hydraulic valve is showing the leak which caused so much grease and crud under the tower. Need to study the parts diagrams and get some orings. Hope there are no cracked lines.
The carb is leaking too. Will get some orings ordered for that also.
Old 03-19-2016, 01:50 PM
Looking good. Nice seat!
Old 03-19-2016, 10:06 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
you are getting there!! Looking great!! I like the seat too!!
Jay
Proud owner of the following:
Old 03-20-2016, 09:31 PM
Thanks for the kind words. Took the leaking line off the hydraulic valve. Found NO o-ring. Matched one up to the line size, put it together and no leak after running for 35 minutes. Smoothed the carb out so it quit surging. Set the neutral on the hydro plate. Turned the front the axle bolt around- had the nut facing towards front of machine
Then I began stripping the Haban deck. I will strip it and ready it for paint. Only real problem is one third of baffle under neath is missing. Hoping get that welded up next weekend.
Old 03-20-2016, 10:46 PM
jaynjeep's Avatar
Steve,
Those Haban's are great decks!! Easy to work on also.
You will love the 2182 combined with the 60" Haban.. Its a great pair!!
Jay
