Old 06-25-2017, 12:39 PM
IHinIN IHinIN is offline
Looks good! I'm going to try to get some painting done on my 100 this week.
Old 06-25-2017, 01:36 PM
Terry C's Avatar
Terry C Terry C is offline
Looks good!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-25-2017, 01:41 PM
smalljob's Avatar
smalljob smalljob is offline
Thanks guys.... I enjoy working on the old iron.
Old 06-25-2017, 02:24 PM
Dirty Steve's Avatar
Sure is looking quite nice. Keep at it!
Old 06-27-2017, 06:32 PM
smalljob's Avatar
Made sure it was in neutral, set the brake, disengaged the PTO and turned the key. No matter how many times I have done this I am always anxious to see if it will start.
The seat is painted, but I want to let it dry another day or two before I mount it. Then I will try driving it.
This was first start so still need to do some tweaks. Want to recheck the point gap and of course dial in the carb.
https://youtu.be/fCuChoLuIXc
Old 06-27-2017, 09:13 PM
Lol. I can certainly empathize!! I've had hundreds of engines apart. After an overhaul it brings a certain rush to hear it run the first time. I'm always shocked if they don't start in a couple cranks, because that has not happened to me very many times. But that feeling you get hearing a motor run for the first time does give you a feeling all its own.
Old 06-27-2017, 10:43 PM
smalljob's Avatar
It happened to me last week. A friend brought over his Case 444 with a K321 running terrible. I pulled the carb and did a thorough cleaning. Put it back together turned the idle and high speed jets down to their seats and then I was interrupted before I could set them to their initial settings. An hour later went to start it and it just cranked???????
Fortunately only took me a minute or two to remember that I had not set them up. All was well after that.
Old 06-27-2017, 10:47 PM
I tried starting my freshly rebuilt K301 with the coil+ wire hooked to the - post on the battery. Took me a few minutes to find my goof up.
Old 06-28-2017, 05:35 PM
smalljob's Avatar
Took it out for a spin this afternoon. https://youtu.be/A8VicwlGbk4
Now I have to work on the hood. It is a little out of shape, but not too bad. The cross piece is broken out, but as part of my spare parts I have a hood from a 73 that has the piece. Measurements looks like it should fit. I can't use the 73 hood because it is shorter than the 100 hood.
I also have the 3 pt hitch painted so that can get installed in the next day or so. I am also going to have to make a decision on what I want to do with the tires / rims.....
Old 06-28-2017, 08:39 PM
You're better off making a new hood brace out of thicker metal so that it doesn't break again. Trying to cut the brace from the other hood would be a lot more work than making a new one. No reason to ruin one hood to save another if you don't have to. I made a new brace for my 100 from 12 or 14 ga.
