Old 10-28-2017, 11:10 PM
When in doubt, ask, and you shall receive the answer.
Someone's been there, done that.
Looks good.
Old 11-20-2017, 03:11 PM
smalljob's Avatar
smalljob smalljob is offline
Finally had a break from storm and leaf cleanup yesterday and started the wood stove in the barn. Got it up over 60 degrees and got the hood painted. Last painting of the season. I want to get the decals installed. I have installed many decals over the years but these original decals for the hood are a tad different. It looks like some of the letters are separate, for example C U B and C A D E T are all individual. It also looks like the I for international is separated from _nternational.
Usually I spray the area good with a mix of water and soap detergent so I can move things around and get bubbles out. I usually apply the decal then pull the backer off slowly while everything is still wet and then work out any wrinkles or bubbles. If I do that with these I risk the individual letters moving. Has anyone ever tried leaving the backing on until everything is dry and them wetting it good to remove?
What do you guys do to get the best results?
Thanks
Bill
Old 11-20-2017, 04:04 PM
You can leave the transfer tape on until it's dry and it will peel right off, no need to wet it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-20-2017, 07:20 PM
C5rider C5rider is offline
That IS true, but wetting it will allow you to move the decal around a little before it sets. I left the backing on until it was situated and then slowly pulled it back at a steep angle. Some of the edges might have tried to come up, but you can catch it pretty quickly before things get too out of whack.
Good luck!
Old 11-20-2017, 07:31 PM
zcub22 zcub22 is offline
Default Beauty
Beautiful job on that one.
Old 11-20-2017, 07:36 PM
Good luck!
He asked about putting them on wet and then letting them dry completely before removing the transfer tape, he wasn't asking about putting them on dry and I wasn't suggesting he do so.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-20-2017, 09:21 PM
smalljob's Avatar
Thanks guys
I hope to install them in the next week
I get some pictures when done
Bill
Old 11-22-2017, 10:52 AM
smalljob's Avatar
A rainy day project. Thanks again for everyone's advice. A little before and after.
I think I have most of the tedious painting done, engine, clutch, grill and hood. Next spring the frame and rear end.
Old 11-22-2017, 12:22 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Beautiful work Bill!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-22-2017, 06:57 PM
smalljob's Avatar
Thank You
Bill
