Old 04-21-2019, 12:27 PM
IHCubCadet147's Avatar
Looks great!
Old 04-23-2019, 09:57 AM
ColoradoCadet's Avatar
ColoradoCadet ColoradoCadet is offline
Originally Posted by IHCubCadet147 View Post
Looks great!
Thanks. I drove it around in the backyard a little. Tough to find neutral and stick it, which is kind of scary. In the homestretch now!
Wayne
Old 04-29-2019, 05:53 PM
As I grow closer to completing my rebuild I continue to run into small annoyances that demand attention. There were door hinges holding the hood on, I bought a piano hinge to replace it but none of that worked - so I have an appropriate hinge on order. The cheap carb I bought wouldn't work because the choke was upside down - even though the tractor runs great with it. Anyway, after much effort I determined I could could take the choke arm out of the old carb and stick in the new one. Of course the screws broke off and one had to be drilled out and the other one put up quite a challenge too. But now the choke works. Applying the brake put the tractor in reverse and I couldn't get it adjusted right .... found the rod was worn quite bad so I have another one on order - hopefully I will get the adjustments right after it arrives. Meanwhile ..... it continues to sit and rest.
Wayne
Old 04-29-2019, 09:16 PM
ironman's Avatar
ironman ironman is offline
Small (and large) annoyances are what you learn from. The next tractor you do will go so much easier because your experience with this one will have taught you to look at all the fine details even as you are tearing it down. If you catalog your trouble spots as you see them coming apart, you can have fixes in place or replacement items on hand for a less stressful reassembly. The end is in sight, nice job.
Old 04-30-2019, 07:21 AM
sawdustdad's Avatar
Wisdom abounds here!
Old 04-30-2019, 10:06 AM
Absolutely on all points!
Wayne
Old 04-30-2019, 11:06 AM
ironman's Avatar
Kind words from the "Yoda of Tandem Cubs"
Old 05-11-2019, 03:47 PM
Well, it's been about 6 months and other than a few tweaks I think I'm ready to call it done. Next cub project will be to redo the trailer. Rather than all white I think it will wear yellow fenders.
Wayne
Old 05-11-2019, 07:35 PM
twoton twoton is offline
Looks great! You did a nice job.
Old 05-11-2019, 07:51 PM
scgtguy's Avatar
scgtguy scgtguy is offline
Default nice unit
uber good on the air cleaner detail ... cool enough
ive always liked the 149 ... kinda like a quit line without shrouds
enjoy !
B.
