#91
Thanks for the link, Mike!
#92
I'm getting ready for picture over load!
#93
Looks great Mike!
Thanks for the update!
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
#94
I have been following this thread and like the work you have done. I was curious if you got the brake/clutch split done? If so how did it work out?
#95
Looks great, luv a good resto thread.
#96
Sorry guys as my progress is frustratingly slow at the moment & has been for a while. I've had a rash of broken parts, which leads to finding replacement parts & having overall difficulty trying to get the little guy back together. Since the last update I made a stub for the implement handle to move the rear lift up & down, got the steering fairly squared away (needs a little adjustment, no biggie), got the dash tower remounted, my drive clutch/driveshaft assembled with IHinIN's pivot support (SWEET!) and put the little guy back on his wheels. Now the bad news... The motor is giving me huge problems. I'm on my 3rd flywheel (I broke one, USPS smashed my replacement & now my current one) and it doesn't want to seat all the way on. The sheetmetal shroud over the flywheel needs to go on another 1/8" before the holes in the line up with the screw holes in the plate under the flywheel. Smashed my clutch drive pulley in the process of putting the flywheel on. Not sure what to do now. Wondering if maybe the key is too far back & is sticking on the ramp near the end of the slot. haven't taken the flywheel off yet to look. Here are some new pictures. ![]() Rear lift Stub ![]() Smashed Drive Pulley ![]() ![]() Flywheel in it's current state
Mike - Ramsey, MN'65 100 - #126432 Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles "Why buy something shiny & new when you can save something old." |
#97
Mike looking good!
#98
Very nice, Mike!
#99
Think I figured out why the flywheel didn't want to go on all the way; I had the wrong size key in the keyway. Pulled the flywheel off, removed the key & slid the flywheel back on until it stopped. Slipped the shroud on and I had a between a 1/16" & 1/8" clearance between the fins and the shroud. I think that should be enough... Sorry guys, no pictures at the moment.
#100
What size key is correct for a K241as crankshaft & flywheel?
