Old 03-28-2010, 09:19 PM
dads70's Avatar
dads70 dads70 is offline
Default grinnin like the town idiot
well fired up the lil 70 hooked her up to a trailer and hauled some tree trimmins from the yard to the burn pile. wife said i was grinnin like the town idiot:biggrin2.gif: have you hugged your cubby today? dang i love this lil ol tractor...
also adjusted the brakes she'll stop on a dime now
Old 03-29-2010, 12:08 AM
redwaycc's Avatar
redwaycc redwaycc is offline
the weather was perfect so i hooked up my plow to my now running 129 and had a ball. i first tried it out with my 23x10.5 turfs and it went ok but the tires are to wide so i put on some 23x8.5 turfs, double wheel weights, and chains, and got after it. i had never used a plow before but it went so well that i doubled the size of my vegetable patch.
100(2) 128, 129, 76(1/2)
Old 03-29-2010, 12:31 AM
ihnick's Avatar
ihnick ihnick is offline
wish my 129 looked that nice. yeah ive tryed plowing with just turf tread before. didnt work that great haha
Nick.
Old 03-29-2010, 12:34 AM
Great pics, redwaycc! Thanks for sharing.
Old 03-29-2010, 02:36 AM
Glad you had a ball even if you did happen to look like some of your wifes family!
Old 03-29-2010, 02:42 AM
Attachment 2821Attachment 2822Attachment 2823
Wish my dirt looked that good. This Carolina red clay is nothing like the dirt back home in Michigan. Dirt shouldn't stain your clothes!
I hope to being doing some plowing soon! Got pick up some new toys next weekend! Pictures and hopefully video's to follow!
Old 03-29-2010, 08:55 AM
eastonct124's Avatar
eastonct124 eastonct124 is offline
The steering's been getting harder on the 124, so yesterday I put it up in the front, tore down the front end, and the axle.
All the grease was dried up.
I modified the front pin for the axle when I had the engine out last....I put a 3/4" OD, 1/2" ID bronze bushing all the way through, then a shouldered 1/2" bolt with a Lock nut. The bolt goes in through the front, nut in the rear.
Makes things alot easier.
So, all greased up, and back together. Much better.
I'm going to be putting bearings on the spindles soon, top and bottom....but haven't had the time.
Oh, and I made a spring assist....did it WF style. Bolts to the deck lift arm. Then made a strong angle bracket and bolted it on the side of the seat support panel. No, long angle rod needed....put it low so to tighten it, I use a socket on an extension, under the 3pt lift arm.....Chain with a shackle to the arm, then a 12" heavy spring from the chain to a eye-bolt.
Woks nice....cost nothing.
Fly Fishing is not a sport...It's a way of life.
Old 03-29-2010, 01:30 PM
Magnum Magnum is offline
Is that a gearbox attached in the second picture?
Can you leave the gearbox on year round, will it interfere with the plow or anything?
Old 03-29-2010, 01:45 PM
redwaycc's Avatar
yes, that is a gear box and i had wondered if it would be a problem. in some areas the furrow was deep enough that i was pushing dirt with the mule drive. i have the PTO set correctly and disengaged so the belt does not move. if it did then it would be chewing up everything in its path and that would be a problem.
Old 03-30-2010, 03:43 PM
Hauled some limbs to the woods. Had some bad storms late Sunday night, into early Monday morning. Eight tornadoes were reported in NC. Sorry, no pics this time.
