Old 11-22-2017, 06:38 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I got the steering box pulled out today. While getting it out I broke the u-bolt and the o-ring in the upper CV joint was messed up. Taking it apart I found the gasket holder is bent up, the cam follower has flat places on it, the upper plastic bearing guide was in several pieces in the grease and I only found 5 balls on the top bearing. I assume there should be 8 balls on the top bearing.
Cannon
Old 11-22-2017, 06:45 PM
sorner's Avatar
sorner sorner is offline
Good point Terry, I wonder why it has two balls and a shaft, and the driveshaft has 4 balls?
There’s a joke in there, somewhere.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 11-22-2017, 07:21 PM
Looks like it is time for a rebuild.
Old 11-22-2017, 08:39 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Cannon
Other than that, how was it?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-23-2017, 11:57 AM
Cannon51's Avatar
This morning I used the gas I had drained out of another mower to clean the cub steering parts. I went through the grease that came out of it and found the three missing balls. So now I'm just missing one cage on the bearings. I put all the loose parts in some diesel fuel. I did some reading and there seems to be conflicting opinions on whether the cage is necessary. Anyone bought stuff from this guy? https://www.ebay.com/itm/Cub-Cadet-C...%257Ciid%253A1 Happy Turkey Day to all.
Cannon
Old 11-23-2017, 12:07 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Cannon
I have rebuilt many older Jeep steering boxes over the years.. the older ones did not have bearing cages.. the balls just floated.. the newer boxes did have a flimsy plastic cage. I have been told all the cage did was make it easier to assemble.. I'm pretty sure you don't have to have the cage. I have bought stuff from that guy before.. everything fit and worked well Good luck with your project!
Happy Thanksgiving!!
Jay
Proud owner of the following:
Old 11-26-2017, 07:52 PM
17xt3 17xt3 is offline
Had good weather so I tilled the garden.
Old 11-30-2017, 05:59 PM
Cannon51's Avatar
I went by an industrial supply house this morning to see if they had the o-ring for the Upper CV joint on the steering. They did have it but the guy said they had a $5 minimum order so I would have to buy 10. I put some grease in it and put it back together. I could have got the box out by just taking the bolt out of the shaft but I didn't know it at the time. O well it needed grease anyway. One of the back tires has been leaking so I put a tube in it. I'm still waiting on the follower pin I ordered on ebay to start putting the box back together. I'm planning on making the gasket, how thick should the material be?
Cannon
Old 12-03-2017, 07:57 PM
89cubcadet1772's Avatar
89cubcadet1772 89cubcadet1772 is offline
Got the old girl ready for the snow.
89' Cub Cadet 1772
Old 12-05-2017, 08:10 PM
Cannon51's Avatar
I got the parts for my steering box yesterday and got it back in the 1641 today. It rained most of the day here so I didn't test drive it but it's got to be better than it was.
Cannon
