Old 12-04-2018, 03:18 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
While I had the cover plate off the underside of the 1863 I decided to touch up the paint a little. I worked on both sides with a cup brush on the 4 inch grinder then washed it down with paint thinner. I brought the cover and the Rusty Metal Primer in the house to warm up before I spray it. I'm out of the 'close enough' yellow I use so I'll need to pick up another can of it. I got this gallon of thinner at Walmart a few weeks ago and didn't notice that it was "Environmentally Friendly". It doesn't even smell like thinner.
Cannon
Old 12-23-2018, 11:32 PM
Vrobert's Avatar
Vrobert Vrobert is offline
Default practice with the mig welder, snow blade repair
I have a snow blade with one of the cotter pin holes blown out. See pic. Not sure how the PO did this but I'll fix it today.
Cleaned it up a bit with a Norton Blaze disk and wrapped it with copper to keep the weld from mushrooming. Then I dropped a steel washer on it so I didn't need so much wire. Then I filled it up with mig steel. See final product.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 12-24-2018, 12:03 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Looks great! Now hit a stump or curb at 3 mph and see if it holds. I know factory will.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-24-2018, 12:18 AM
Vrobert's Avatar
I figured I only have to be stronger than the cotter pin. Time will tell.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
Old 01-13-2019, 11:32 AM
Cambria cub Cambria cub is offline
Default Snow plowing
Finally got to plow some snow with the 1811.man did she do good big difference than using the 128 sorry for the pics
Old 01-14-2019, 12:12 PM
Good looking 1811!
Old 01-14-2019, 05:16 PM
Thanks Allen! First time I posted pictures that are sideways
Old 01-20-2019, 10:54 AM
Joel H's Avatar
Joel H Joel H is offline
Default What I did with my Cub Cadet today .
IMG_2565.jpg] Todays snowstorm in Maine . Cub Cadet 1450.
Old 01-20-2019, 11:27 AM
twoton twoton is offline
Wow man! That thing is blowin' some snow!
Old 01-20-2019, 12:50 PM
We did the same around here yesterday.
Made quick work of the 6-8" that piled up overnite Friday
