Old 02-06-2022, 07:20 PM
Farmall450's Avatar
Originally Posted by Mr Bob View Post
If you are able to do it your self, that is the way too go. I am getting too old to do too much. It was extremely difficult to get those heavy tires mounted to tractor. Have a great day.
Bob
Thanks Bob! I don't plan on taking them off the tractor, but running the valve stem up and pumping in as much as I can
Old 02-12-2022, 05:23 PM
Farmall450's Avatar
Got the 1782 inside the shop today. Messing around, good on oil and coolant, newer filters.
Glow plugs work and get 9v. Fuel pump works. Cranks good. No smoke, but I also noticed the fuel solenoid on the pump doesn't engage or disengage (move) on it's own, even when cranking, which I figured it would.
12 degrees though, so I threw it on the battery charger for warmer weather. Going to pickup a diesel compression tester tomorrow after work and check that out firsthand this week.
Old 02-15-2022, 10:57 PM
Farmall450's Avatar
Aquired this rough little 1862 last night. If I was smart I'd put the #450 blower on it to take advantage of the power steering, but it's hydro controls are pretty lose and was def ran hard and put away wet.
I think this is going to go live down the road to push snow/back in trailers there. I wasn't aware non-supers had power steering until a few months ago, so this was a neat find for me.
Old 02-16-2022, 12:41 AM
1811woody's Avatar
No wonder I cant find any cubs, you buy them all lol
Old 02-16-2022, 09:39 PM
Farmall450's Avatar
It's not intentional
Tried to start the 1782 today (it hit 49). Smoke, but no luck. Compression tested all 3 cylinders in the mid 100s (way too low). Pulled off the head but didn't find any smoking guns -- will have to clean up and inspect further.
The headgasket looks OK, so besides valves being gummed open I'm not sure where else to look. Oil didn't noticeably improve the compression, so I don't think it's the rings.
Old 03-18-2022, 10:31 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Weather has been nice this week, so I decided to bring the 106 and 107 out of winter hibernation yesterday evening.
The 107 gave me no trouble. Checked for mouse nests (all clear) Hooked back up the battery, which still had a charge, opened the fuel shutoff, pulled the choke, and the engine spun around 10 ish revolutions and then fired right up and ran just as good as it did when I parked it for winter. Took a little drive and all was good.
The 106 was a different story. It fought me but I eventually got it. Didn't take me too long to diagnose that it wasn't getting any gas. Pulled the carb off and there was, what I assume to be ethanol, gelled up in the bottom of the bowl, blocking off the main jet/emulsion tube.
Cleaned it all out, reassembled and reinstalled, then tuned it, and the 106 is back up and running. By then it was too dark out to take any pictures but I did go for a little drive as well.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 03-18-2022, 12:18 PM
Always good to take a drive after the lay off.
Ken
Old 05-04-2022, 11:33 AM
ChristopherCT ChristopherCT is offline
Default Used 129 with trailer, moved soil, broke down in the woods
Last week I used our #129 to move a bunch of soil into this relocated planter. The planter holds about 600 lbs, so I do 300 twice. I was given this trailer by my friends at the dump, and its much better than my last one which was rusty, paper thin and with tire tubes pressing right through cracks in the wheels! This trailer might be an IH brand, but I'm not sure. It has no makers marks I can find. I would like to scrape that college sticker off it and paint it one day.
Then I moved a bunch of brush into the woods to dump it. The Kohler 301 would NOT start. I had noticed that choke position had gone weird that week, and that I did not have a lot of power. I determined that no fuel was rising UP from the carb bowl. So for the first time ever- and in the woods- I took apart the carb to examine its tubular needle. It LOOKED okay. After cleaning out its holes with a tiny copper wire and spraying cleaner through it, I hoped that was the problem.
It fired up with cheer, and now I think it runs better than it has in months! Maybe soon I should change the aging fuel filter... I also read that I can buy fuel nearby with no ethanol in it. I HAVE been adding a little stabilizer in winter months.
Old 05-04-2022, 11:57 AM
The next step in the education of these tractors. Nicely done on the in the
field repair.
Ken
Old 05-06-2022, 08:01 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Time to clean the bung (and replace the fuel line)
100% humidity? Direct sun? Clogged up fuel system?
We're going to fix that!
(I replaced the tank<>1st filter line and got the gunk out of the fuel feed in the tank. All is well now, it's just a tedious repair.
Tomorrow I'll clean it all up and change the oil and grease the fittings on the deck.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
