Old 05-31-2020, 10:16 AM
Merlin2014 Merlin2014 is offline
Nice looking herd.
Old 06-14-2020, 11:21 AM
cub123's Avatar
cub123 cub123 is offline
Pulled the tiller off the 123 and put the deck on on to help the 1782 with grass duty.
File Type: jpg EA76FD6F-0841-4435-A7ED-843C6D662071.jpg (34.3 KB, 176 views)
Old 06-14-2020, 11:46 AM
Nice to see your still around Ben.
Old 06-15-2020, 08:10 PM
herm1 herm1 is offline
Brought the new Cub home!
File Type: jpg 2D73E117-4593-49DC-AA9F-894D126D8B2B.jpg (32.1 KB, 151 views)
Old 06-15-2020, 09:01 PM
aagitch's Avatar
aagitch aagitch is offline
What model is that? Does that use a driveshaft? Nice looking!
Adrian
2072 (789513)
Old 06-15-2020, 10:12 PM
IHCubCadet147's Avatar
Congrats on your new tractor! Hope it serves you well.
Old 06-16-2020, 05:02 AM
It’s an XT3 GS and it does still use a driveshaft. I had to get something to give my 1810 a break and fix some issues that I’ve been putting off for a while.
Old 06-23-2020, 09:09 PM
Nice cubs, guys!
Old 06-25-2020, 07:44 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Smile
I added Stewart Warner oil gauges to both of my Cubs- a 1985 1711 and 1986 1811. The install was pretty straightforward. On the 1811, the brass adapter fitting snapped off in the block. I drilled it out and tapped for 1/8"NPT. I added an adapter so that the low pressure switch/idiot light was retained in addition to the new gauge. The Kohler M18 in my 1811 has 1900 plus hours on it. I run Rotella SAE30 oil. After 20 minutes at 80 degrees ambient temp, the oil pressure is almost 60 psi indicated at full throttle while mowing. This should have been standard equipment on all Cubs with a pressurized oiling system.
Old 06-25-2020, 09:27 PM
Very nice!
